Rep Power: 16 ![]() |
Dear All,
I have noticed similar problems posted in other threads but without being resolved, apologies if I have missed another thread where this has been answered. I am writing a UDF involving the K-omega model, as written in the Fluent 6 manual, however to calculate the turbulent viscosity I need the strain rate magnitude S and the blending function F2. For S, I think I can use C_STRAIN_RATE_MAG(c,t) although I am unsure if there is a variable for the blending function, none is listed in the UDF manual...does anyone know of one? failing that, does anyone know how the variable function of y, the distance to the next surface, is C_WALL_DIST(c,t) what I am looking for? Thanks in advance for your help |
ali
Rep Power: 17 ![]() |
Were you able to solve your problem? |
blending function, k omega sst, udf |
Dynamic Mesh UDF | Qureshi | FLUENT | 7 | March 23, 2017 07:37 |
UDF parallel error: chip-exec: function not found????? | shankara.2 | Fluent UDF and Scheme Programming | 1 | January 16, 2012 22:14 |
How to add a UDF to a compiled UDF library | kim | FLUENT | 3 | October 26, 2011 21:38 |
Defining deformable mesh UDF to set omega | Chris | FLUENT | 0 | August 30, 2006 16:01 |
UDF...UDF...UDF...UDF | Luc SEMINEL | FLUENT | 0 | November 25, 2002 04:03 |
