Fluent PEMFC add-on modul
Old   June 21, 2010, 16:03
Default Fluent PEMFC add-on modul
kidloco is on a distinguished road
Dear all,
I am wondering is it possible to made a 2-D model in Fluent PEMFC-modul?
I didn't have any problems with 3-D model. After i create my geometry in Gambit and meshing and defining boundary conditions i simply load a case in 3D fluent.
I also try with 2-D in x-y plane but after solving in fluent i didn't get solution (i get 0 current density for anode and cathode).
Also i would like to ask, for which exchange current density for anode and cathode you get the most realistic results (polarization curve)?
Thank you for your answers,
Regards, Ivor
kidloco is offline   Reply With Quote
Old   June 23, 2010, 04:05
bob12 is on a distinguished road
hi
i use a sofc model but don't function well because some user memory are 0 all field in 3D simulation. how many strate of cathode and anode you use?
thank you
any suggestions are welcome
bob12 is offline   Reply With Quote
Old   June 23, 2010, 04:32
ender is on a distinguished road
I am working on 3-D single straight channel pem electrolyzer model.
Pem electrolyzer model is working, but outputs are incorrect. I am collecting oxygen from anode.
Originally Posted by bob12 View Post
hi
thank you
ender is offline   Reply With Quote
Old   August 7, 2012, 08:26
Emad
elemad1987 is on a distinguished road
Send a message via Skype™ to elemad1987
guess what happen History repeat it self.
I have the same problem as you
I am using the Fluent 14 and I want to simulate a PEM fuel cell.
The only tutorial of PEM fuel cell of Fluent is from 6.3 version.
I use it to Fluent 14 and I follow the steps but the results does not the same, also some data and parameters are different.
Anybody know if the tutorial of 6.3 Fluent is working to Fluent 14 too?
I think now you had finish your thesis peacefully.
Can you help me to overcome my problems.
or send me your cas files
Thank you
Emad G.
elemad1987@gmail.com
elemad1987 is offline   Reply With Quote
Integration of a Custom C++ Model into FLUENT Syed Haider FLUENT 2 March 7, 2018 00:37
How to open Icem mesh in Ansys Fluent? emmkell FLUENT 27 February 6, 2018 04:34
Master node in parallel computing only distirubtion syadgar FLUENT 1 September 8, 2009 17:41
On Bug of Fluent 12.0 lzgwhy FLUENT 0 August 26, 2009 07:41
HOW TO ADD ENERGY SOURSE IN FLUENT! Devy FLUENT 0 March 22, 2001 07:08
