Please help: Fluent 12.1 doesn't run on my AMD X4 630 2.8Ghz PC with Window 7
Old   June 14, 2010, 18:16
Default Please help: Fluent 12.1 doesn't run on my AMD X4 630 2.8Ghz PC with Window 7
Andy_Eco
andy.eco is on a distinguished road
Dear Fluent community,
I am looking for your help and your experience in running Fluent 12.1 on AMD PC and Window 7.
After installing Fluent 12.1 on my new (64 bit) computer, I cannot use it. The software worked on my old one with Window Xp 32 bit on it. The new PC has AMD Athlon II X4 630 2.8Ghz, 6GB RAM and Window 7.
When I started, Fluent loaded successfully dmp files but stopped response after (or while) reading patch(es). Here are the screen messages:
Loading "\ANDY-PC\C$\ANSYSI~1\v121\fluent\fluent12.1.4\lib\fl114-64.dmp"
Done.
Loading "\\ANDY-PC\C$\ANSYSI~1\v121\fluent\fluent12.1.4\lib\flprim 1119-64.dmp"
Done.
Host spawning Node 0 on machine "Andy-PC" (win64).
You can press CTRL+C to stop the startup process!
This product has the following patch(es) applied:
patch_12.1.4_win64_1
You can find more information about the patch(es) in the
respective text file(s) located at:
"\\ANDY-PC\C$\ANSYSI~1\v121\fluent\fluent12.1.4\win64"
Does anybody have experience with this issue, please share your commends.
I appreciate your help.
Andy Eco
andy.eco is offline   Reply With Quote
Fluent 12.1 on Linux x64 Architecture Issue fivos FLUENT 5 April 24, 2010 16:19
how to generate a long annulus then run in FLUENT zhu chen Main CFD Forum 0 March 27, 2004 19:42
Running Fluent on Linux AMD machine David Reinbold FLUENT 5 September 21, 2001 18:08
Can FLUENT run under Linux with 2 Gb of RAM? Paul Gregory FLUENT 0 February 13, 2001 21:10
Run Fluent in batch mode Shengping LUO FLUENT 2 October 24, 2000 06:42
