Simplified VOF Model
Old   June 10, 2010, 16:57
Default Simplified VOF Model
gulbenkian is on a distinguished road
Hello
I am trying to solve a transient simplified model in 2D. Air is flowing from a source at 200000 Pa and get into contact with a pool of water of 2mm X 4mm before expands to atmospheric conditions see Figure 1.
I want to see the deformation of the water (droplet formation if any) due to the air flow. I am having problems to get convergence in the model. I am using a VOF model using air as primary phase and the water as secondary phase. As boundary conditions I am using a pressure inlet and pressure oulet conditions. I am patching the water at the beginning. I have used a k-e model and a simplified laminar model for the air and a time step size of 0.0001, however, after I begin the iterative process, it quickly diverge.
I highly appreciate if someone can give me some ideas.
Thanks in advance
gulbenkian is offline   Reply With Quote
Old   June 10, 2010, 17:52
pranab_jha's Avatar
Pranab N Jha
pranab_jha is on a distinguished road
What error message does Fluent give you?
I am also using VOF and facing some issues with divergence. I am modeling two-phase flow in pipe. I got the error msg: "divergence detected in AMG solver: pressure correction" when I initialized the whole pipe domain with VF =1 or even with VF = 0.5. But for low phase velocities, I was able to 'avoid' divergence by lowering the relaxation factors for pressure from 1 to 0.5. But I am not able to get around it for higher velocities (air and water ~ 1.5 m/s, pipe dia = 50 mm) by lowering the value further.
I guess you can try it. Maybe it works for you. If you come across any useful tip, do let me know.
Thanks,
Pranab
pranab_jha is offline   Reply With Quote
Doubts UDS Flux, UDS Unsteady for VOF model kel85uk FLUENT 0 March 17, 2010 09:53
VOF Model or Mixture Model mems21 FLUENT 2 March 9, 2010 11:37
A Problem with setting the time step in VOF model Le FLUENT 2 July 20, 2006 23:00
free surface of VOF and melting model? wanghong FLUENT 3 March 13, 2006 10:57
help needed for vof model yan FLUENT 3 December 16, 2005 02:17
