June 10, 2010, 05:41 |
Inlet but not outlet
Mireia Ayop
Rep Power: 16 |
Hi!
I'm starting with FLUENT. I have a simple model: an enclosure with an inlet and an outlet. I use compressible Xenon as fluid and I would like to find the pressure at the outlet giving some conditions at the inlet. As if I impose in Gambit that the outlet is 'pressure_outlet' FLUENT obliges me to specify a pressure there and as I work with compressible fluids I cannot use the 'outflow' boundary condition... Should I impose that my outlet is an 'interface'? Or... is there any way in FLUENT to modelize this kind of problems entering only the conditions at the inlet? I don't want to impose any condition at the outlet. Thanks |
June 10, 2010, 11:56 |
Anirban Jana
Rep Power: 16 |
Isn't the "pressure drop" the important quantity (especially if your flow is incompressible or almost so)? In that case you can have a velocity inlet and a pressure outlet, and set the pr at the pr outlet to zero (just a reference pr), and after simlulation note the pr at the vel inlet.
Hope that helps |
steam flow in a pipe driven by a pressure gradient between inlet and outlet | SalvoCalvo | COMSOL | 0 | March 11, 2010 07:52 |
VOF Outlet boundary condition in cfd - ace | JM | Main CFD Forum | 0 | December 15, 2006 09:07 |
inlet and outlet boundary condition of pump | Thammasak | CFX | 0 | February 9, 2004 14:02 |
Question about inlet and outlet BC | babyface | Main CFD Forum | 1 | January 15, 2003 10:17 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 06:13 |
