I have a problem with the sign of mass flow rate Enthalpy
Old   June 6, 2010, 19:02
Default I have a problem with the sign of mass flow rate Enthalpy
Behrang Asgharian
behrang2009 is on a distinguished road
I put some Lines (from the menu 'surface-line') on my model in order to monitor the enthalpy flow rate. I use the flow rate integral which is
integral of rho*h*u.dA
the absolute values are OK but the sign is negative when it must be positive. I think this has got something to do with the inner product of u.dA.
Does anybody know how I should define the monitor line in order to get positive enthalpy flow rates?
By the way, if I use 'surface-rake' instead of 'surface-line', what will happen?
Thanks
Behrang
behrang2009 is offline   Reply With Quote
Mass flow rate: calculation v/s computation beguxa FLUENT 5 December 2, 2018 22:02
mass flow rate of "interior" Dong Fu FLUENT 0 February 1, 2008 12:25
particle, parcel and mass flow rate balance flybird FLUENT 0 May 24, 2007 11:44
Mass flow rate Neser CFX 4 February 14, 2004 01:27
Possible?: Periodic conditions with non-constant mass flow rate. Ray FLUENT 0 April 10, 2000 07:10
