simulation of an air conditioned room using fluent and gambit
Old   May 27, 2010, 18:51
Question simulation of an air conditioned room using fluent and gambit
abhi8288 is on a distinguished road
hi all...
I am doing thesis project in which i am required to simulate an air conditioned room using fluent and gambit.I need some help with the modelling and specification of boundary conditions part.I want to specify a mass flow inlet at a n angle.how can i do that apart from making the edge slant? also,i am trying to simulate human beings as a rectangular box with wall BC with certain heat flux specified but after the iterations it doesnt show any heated area near the device.any help in this regard is highly appreciated.
thank you..
abhi8288 is offline   Reply With Quote
Old   June 21, 2010, 12:53
Default Hello
Kavita
kavitagangisetti is on a distinguished road
I am also doing my thesis on similar topic.
1). You can specify the direction of your flow in mass flow inlet by giving - Direction vector in direction specification method. There you can select the coordinate system (Cartesian, cylindrical, spherical etc..) and then give the components accordingly.
2).If you have defined the heat flux surfaces (i.e persons or computers), then you should get respective temperature on the surface and heat should be carried away by fluid based on h. Make sure that energy equation in on and grid is refined near the surface.
Hope that helps,
Kavita.
kavitagangisetti is offline   Reply With Quote
Old   June 21, 2010, 16:01
hey kavita..thank you..i appreciate ur reply...i have another problem concerning my project..the thing is i want to model people inside the room...for that i have placed a rectangular box on the floor..i am doing a 2 d simulation.. i came across this post :
http://www.cfd-online.com/Forums/flu...tion-term.html
where he says that we need to model the human part as being solid continuum..i am stuck at the gambit part.. how do i mesh the 2 entities ? he asked to split the volumes .. so iam taking the room portion except the box as one face and the box as another face which is solid continnum..but when i imported it into fluent i saw even the box portion to be in fluid continuum..
Old   June 23, 2010, 03:39
Default Hi
Kavita
If you want to separate the fluid zones, it should be done in the meshing stage itself....after importing you should be able to see two different zones in the boundary conditions panel in fluent.
By default , fluent take cell zones as "fluid" but you can always change the zone type to "solid" and specify the solid material in the materials panel.
Old   September 16, 2010, 03:12
Post Modelling, mesh generation and boundary conditions of human being in a classroom
ravi
RAVIKUMAR.TALAPATI is on a distinguished road
I want to make a model of human being as I am doing simulation of air conditioning in class room....
S o can I get how to model, mesh and give heat generation for human beings..
Can I get any tutorials about this topic...
please mail to rtalapati@gmail.com
Thanking you
Ravikumar talapati
RAVIKUMAR.TALAPATI is offline   Reply With Quote
Old   June 18, 2011, 09:45
raghu
chakri.raghavendra is on a distinguished road
On a graph u draw the points and then use the co-ordinates to model it in GAMBIT.. it will be more easy if u model it in Pro- E or any other modeling tool..
chakri.raghavendra is offline   Reply With Quote
Converting Fluent mesh files to Gambit neutral files samuelkc ANSYS Meshing & Geometry 9 April 21, 2021 07:28
Fluent simulation problem & Gambit "database"error Chase Estrin FLUENT 4 February 21, 2013 05:15
SketchUp 3D model import to Gambit or Fluent Steve Johnson FLUENT 0 February 8, 2009 15:21
Facing Few Problems in Fluent and Gambit Ravi Duggirala FLUENT 5 March 11, 2006 04:13
test cases for Fluent and Gambit Ben FLUENT 1 May 21, 2003 07:44
