May 26, 2010, 10:11 |
Pressure Inlet BC Convergence
Ian Helms
Rep Power: 16 |
Hi all,
I am running a steady flow simulation through an NGV blade row. I'm using the pressure-inlet and pressure-outlet BCs. I expected the inlet velocity to be on the order of 120 m/s (M=0.3), and when I initialize the flow the initial value says 120 m/s. However, the converged solution gives a velocity on the order of 70-80 m/s. My understanding is that if the inlet flow is subsonic, the inlet velocity is computed via isentropic relationships, but I don't understand why the final velocity would drop so significantly. |
Domain Reference Pressure and mass flow inlet boundary | AdidaKK | CFX | 75 | August 20, 2018 06:37 |
Pressure Inlet Boundary Condition | Prasad | FLUENT | 6 | April 9, 2013 22:32 |
steam flow in a pipe driven by a pressure gradient between inlet and outlet | SalvoCalvo | COMSOL | 0 | March 11, 2010 07:52 |
How to give pressure inlet in Fluent | Vijayaragavan | FLUENT | 2 | December 13, 2007 04:21 |
Reversed flow in pressure inlet | eric | FLUENT | 3 | January 26, 2004 21:04 |
