May 25, 2010, 05:53 |
AOA adjustment in CFD compuation.
Luolin
I had a look at the fluent tutorials at http://courses.cit.cornell.edu/fluent/airfoil/index.htm. I noticed that AOA 1.2° instead of 2° were used to calculate the actual AOA 2°. It was explained as a 2d adjustment. ("Note that 1.2° is used as our angle of attack instead of 2° to adjust for the error caused by assuming the airfoil to be 2D instead of 3D.").
Could someone tell me how the 0.8° offset is decided? Is there any theory to support this? Thanks in advance. Your reply is really appreciated. |
May 13, 2013, 07:53 |
#2 | |
Ali
Rep Power: 14 |
May 13, 2013, 09:46 |
OJ
Rep Power: 20 |
The 2D simulation of airfoil assumes that the width of airfoil wing in thierd direction is infinite, and the flow in the third direction is zero. While, in 3D (and reality) the width is finite and there is a finite flow in 3rd direction. Hence, for same inlet velocities, the lift for 2D will be always higher than ones from 3D and hence to realize the same effect of 2deg on 3D wing, the 2D wing uses smaller angle.
There is some explanation provided here to estimate how these different values of angle of attack are related. http://www.mh-aerotools.de/airfoils/hdi_aoawing.htm OJ |
May 13, 2013, 16:50 |
#4 | |
Ali
Rep Power: 14 |
STAR-Works : Mainstream CAD with CFD | CD adapco Group Marketing | Siemens | 0 | February 13, 2002 13:23 |
Where do we go from here? CFD in 2001 | John C. Chien | Main CFD Forum | 36 | January 24, 2001 22:10 |
ASME CFD Symposium, Atlanta, July 2001 | Chris R. Kleijn | Main CFD Forum | 0 | August 21, 2000 05:49 |
Which is better to develop in-house CFD code or to buy a available CFD package. | Tareq Al-shaalan | Main CFD Forum | 10 | June 13, 1999 00:27 |
public CFD Code development | Heinz Wilkening | Main CFD Forum | 38 | March 5, 1999 12:44 |
