May 6, 2010, 15:11 |
Fluent results
Arjit Arora
Rep Power: 16 |
Hi!
On analyzing a 3D wing in fluent, it gave me the following results for force 1. Upward for on the top surface of the wing : 111N 2. Upward force on the bottom surface of the wing : -51N Net result: 60 N lifts! Why am i getting a negative lift for the lower surface?? Conditions: Angle of attack = 8degress Boundary conditions: Velocity inlet at 15m/s, outflow.. wing=wall. other walls = symmetry |
fluent, wing |
Master node in parallel computing only distirubtion | syadgar | FLUENT | 1 | September 8, 2009 17:41 |
Exporting temperature results fro fluent to Ansys | vinay kulkarni | FLUENT | 1 | February 21, 2007 04:31 |
Comparing Fluent Time dependent result with Patran | venigall | FLUENT | 0 | January 13, 2007 20:30 |
Fluent results: stagnation pressure greater .... | Amit Shrestha | FLUENT | 5 | December 8, 2005 09:01 |
Poor Results with RSM in Fluent | boris | FLUENT | 0 | October 31, 2005 19:01 |
