Erroe while startng Geometery(design modeller), in workbench |
April 29, 2010, 09:04 |
Mohammad Waseem Tahir
Rep Power: 16 |
hi
i m having 'Script Error', while i try to go for design modeller to start or edit geometery in Ansys workbench. the error msg is shown in the attached file. can anybody help me out. thanks |
April 30, 2010, 10:51 |
The Problem is solved, may be helpful for somebody in future.
Rep Power: 16 |
Hi, this type of error msg comes when preference directory of workbench becomes corrupted. This directory can be deleted and ansys workbench will make this directory automatically when you launch the application again. Be sure that you have closed all Ansys applications before deleting v121 directory.
C:\Users\SamiOffice\AppData\Roaming\Ansys\v121 It may happen that if you delete the complete directory v121, then the list of components in the tool box changed. In my case this happened to me, so i did not delete the complete v121 directory, but removed only ...v121/en-us, and this worked fine. regards waseem |
ANSYS Workbench on "Uncertified" Linux Distros | hsr | CFX | 289 | April 20, 2023 10:23 |
[Other] CFX 11.0 / Ansys Workbench Design modeller - .geo file | Hectux | ANSYS Meshing & Geometry | 1 | April 7, 2009 06:04 |
