create a probe with fluent
Old   April 28, 2010, 13:05
Default create a probe with fluent
Aenseeiht is on a distinguished road
dear all,
I want to create a probe in fluent to assess the temperature field. In fact, i have an experimental profil of the temperature field that I want to compare to the results given by fluent. Unfortunately, the probes used to do the mesures are not protected from radiation.
So, my idea is to create a probe in the domain of calculation to see its temperature and compare it to the one given by the experiment.
I have tried to do this by making a cylinder, but without sucess beacause this method demand to give a bounadary condition to this cylinder.
Does some know a better idea to achieve my comparaion or a better suggestion to create the probe.
Regards
Aenseeiht
Aenseeiht is offline   Reply With Quote
Old   April 29, 2010, 02:07
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
create a point or a rake in fluent, and monitor your results on those entities
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   April 29, 2010, 04:25
Thank you mAx for tour suggestion,
The probleme with you suggestion is that i cant not incule the radiation on the probe. In fact
Old   April 29, 2010, 04:27
Thank you mAx for your suggestion,
The probleme with you suggestion is that i cant not incule the radiation on the probe. In fact i need to inculde it on the prob beacause the probes used to do the mesures were not protected from the radiation.
Regards
Aenseeiht
Parallel fluent not using all processors specified Paul FLUENT 18 October 26, 2023 04:54
Two questions on Fluent UDF Steven Fluent UDF and Scheme Programming 7 March 23, 2018 04:22
How to create non-uniform velocity profile in FLUENT? pankaj FLUENT 7 October 24, 2016 05:52
how can I create a curved line in Fluent antonietta paulozza FLUENT 3 December 25, 2010 03:40
Fluent equation error?!? TOM FLUENT 6 July 15, 2002 04:24
