April 27, 2010, 23:21 |
Urgent Help Needed!!! (regarding FLUENT UDF)
Deb
Hi
I am a student in Virginia. I am really struggling with a simulation, and would request any help!! Thanks in advance. I am simulating a 2D problem. In my rectangular domain, I have a fluid. I need to move a heat flux along a straight line in the domain. Due to this heat flux, the temperature of the fluid will change, and I will get my desired temp profile. Please note, that the heat flux is constant with time, but NOT with position - i.e. heat flux = q = C*exp(-(x^2 + y^2)), where C is any numerical constant. I tried using F_CENTROID to get the position, but the problem is which macro to use to define the heat flux. with DEFINE_PROFILE I can give such profiles at the boundaries(walls), but how do I give this heat flux in the medium??? PLEASE HELP! looking for assistance in how to set up problem, and how to write the UDF!!! Thanks DSen |
May 27, 2010, 05:41 |
Have you solved it??
C Palani Kumar
Rep Power: 17 |
Hi Dsen,
Just saw your thread. So, what happened with your simulations? Have you solved it? You need to use DEFINE_PROFILE macro itself. I don't think any other macro will do the trick. I didn't completely understand your domain. Can you elaborate a little bit? Palani. |
May 28, 2010, 14:36 |
Allan Walsh
Rep Power: 17 |
Unless you really want to learn how to write UDF's, I would recommend that you take another approach. For a beginner, just to set-up your computer to run a simple UDF, and then implement it, without a lot of testing, you should probably budget at least a week.
A simpler method would be to designate a separate fluid zone in your domain to represent the straight line with the heat flux. (Yes, the zone would have some finite thickness, but modeling is all about discretizing things that are continuous). Actually, the fluid zone representing the straight line would have many separate sub-zones and you can go in in Fluent and set the heat flux (or heat generation) in each of the subzones according to your heat flux formula. Good Luck. |
fluent, heat flux, moving heat flux, udf |
fluent UDF on linux machine | Min-Hua Wang | Fluent UDF and Scheme Programming | 6 | June 29, 2013 09:41 |
Please, Help with linking UDF precompiled outside fluent to fluent!!! | gracerlima | Fluent UDF and Scheme Programming | 1 | May 4, 2010 08:19 |
Parallel Fluent +UDF | Jack Martinez | FLUENT | 0 | June 28, 2007 12:19 |
UDF of Zimont model in fluent | Z | Main CFD Forum | 0 | February 17, 2005 04:07 |
URGENT ! UDF ERROR! | Prateep Chatterjee | FLUENT | 6 | October 16, 2001 20:20 |
