TVR (Turbulence viscosity ratio) and reversed flow |
April 27, 2010, 18:12 |
Deside
Rep Power: 17 |
Hi All,
Can you kindly shed some light on my dilemma. I am having a multiphase transient simulation with velocity inlet BC and Pressure Outlet BC. After a few iterations, i got the messege: turbulent viscosity limited to viscocity ratio of 100 000 in.....cells. This message only lasts for a few iterarions and it dissapears for good. My simulation runs until it converges and as i am trying to simulate some specified time, i am continuing my simulation and after some time i get the message: Reversed flow in...cells...on pressure outlet but my simulation is converging with this message coming up. My question is: Could this undermine the fidelity of my results. Please kindly assist. Thanks, Deside!!!! |
April 28, 2010, 00:17 |
#2 | |
Ling
Rep Power: 17 |
Both are fine.
The turbulent viscosity limit warning is normally showing in beginning iterations and will be gone after certain steps. However, if this warning persists, it normally indicates an improper boundary condition setting or very bad cells somewhere. The reverse flow warning is nothing bad. It tells you that there is working fluid flowing from a virtual outside domain back to your simulation domain through the pressure outlet boundary. You need to be careful when the reverse flow does not physically sound. For example, if you problem is water jet flow into ambient, the reverse flow can only be air while fluent assumes the reverse flow is water. this creates some inaccuracy. Quote:
April 28, 2010, 05:04 |
Deside
Rep Power: 17 |
Thanks astar for the responds. In my case this BC is air at atmosperic pressure which is far from the calculation domain of interest so i think the reverse flow is air as well which i think i have to be comfortable with.
reversed flow at pressure inlet and turbulent viscosity is limited.... | cfdiscool | FLUENT | 10 | June 10, 2015 07:15 |
turbulent viscosity limited to viscosity ratio | Elizabeth | FLUENT | 13 | December 16, 2014 09:57 |
hel (turbulent viscosity ratio limited) for supersonic combustion problem | omar.2002bh | FLUENT | 2 | September 5, 2012 12:04 |
reversed flow &turbulent viscosity | superfool | FLUENT | 7 | August 7, 2007 03:00 |
reversed flow... turbulence viscosity limitted ... | Babu | FLUENT | 3 | February 26, 2005 08:05 |
