Fluent Parallel Processing
Old   April 23, 2010, 02:53
Default Fluent Parallel Processing
Lazuardi Nasution
Mrxlazuardin is on a distinguished road
I'm new to parallel processing on Fluent. Currently I have 4 XP nodes as compute nodes (compute_0 to compute_3) beside the host node. All compute nodes have dual quad cores CPU.
1. Should I run Fluent on all compute nodes or just on host node and compute_0 node? I mean "fluent -t8 -cnf=hosts.txt" command line.
2. What is content of the host file on host node, compute_0 node and compute_1 until compute_3 nodes? On user guide, it seem that compute_0 is special node.
Best regards,
Mrxlazuardin is offline   Reply With Quote
Old   April 23, 2010, 10:00
DoHander is on a distinguished road
1 will work, host.txt can be stored only on your main computer and it must contain the IP addresses of your computers. If you have quad cores CPU put every IP's 4 times, for dual core only twice.
Do
DoHander is offline   Reply With Quote
Old   April 28, 2010, 08:36
Lazuardi Nasution
What do you mean of main computer? Is it host node, compute_0 node or else? Can you give me some example of following items? Please use my hadware case for example.
* Content of host file (for each node if different)
* Location of host file
* Command line for each node
* Execution sequence of command line (node execution sequence)
Best regards,
HP MPI warning...Distributed parallel processing Peter CFX 10 May 14, 2011 07:17
Parallel Processing on ANSYS FLUENT 12 srr FLUENT 2 April 16, 2011 15:16
Fluent parallel poovanna FLUENT 0 March 24, 2007 00:22
About parallel processing in Linux tuks CFX 10 August 8, 2005 09:22
Parallel Fluent on Linux clusters Chengwang Lei FLUENT 3 November 24, 2004 03:05
