HELP:error :Floating point error: invalid number when i drag coefficient udf was used
Old   April 15, 2010, 10:28
Question HELP:error :Floating point error: invalid number when i drag coefficient udf was used
zoesjtuer is on a distinguished road
Hi all,
I'm modeling gas-liquid two phase flow with eulerian model, at the beginning ,the simulation goes well,but when i load a drag coefficient, there is an error after about 50 steps calculation :
Error Object: ()
I've tried to decrease the under relax factor, it seems not useful.what should i do?
Thank you for your answer in advance
zoesjtuer
zoesjtuer is offline   Reply With Quote
Old   September 3, 2010, 03:17
anil
anil raj is on a distinguished road
Initiating the case with wrong conditions may lead to floating point error when the iterations start.
and also wrong boundary condition definition might cause the floating point error
anil raj is offline   Reply With Quote
drag coefficient, error, gas-liquid fow, udf
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 20:43
plotting drag coefficient in low reynolds number flow past cylinder atmcfd FLUENT 0 January 2, 2010 09:34
Solidification drag coefficient atulverma FLOW-3D 1 May 14, 2009 10:24
Need urgent help Regarding Drag coefficient srinivas FLUENT 3 September 20, 2006 11:10
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 13:19
