Trouble when using MUSCL scheme on ONERA M6 wing |
April 13, 2010, 08:33 |
Hi!
I am currently running a simulation on the ONERA M6 wing. The Reynolds number is 11.71 million, the Mach number 0.8372 and the angle of attack is 6.06°. The simulation is running in 3ddp with a structured mesh of 300,000 cells. I am using k-epsilon standard as viscous model and an implicit density-based solver. I have first made the solution converged in 2nd order upwind but when I have switched to 3rd order MUSCL, I have the "turbulent viscosity limited to viscosity ratio" problem which has appeared after only 5 iterations. The number of cells concerned about this problem increased until 14,000. I have read in Fluent user's guide that there is no flux limiters in the MUSCL scheme inplemented. So my question is: do you think my problem is due to this specification? Thanks. Regards, Aurélien |
November 29, 2012, 10:38 |
Mr Malik
malik
Rep Power: 14 |
Hi Aurélien,
I am doing a project on shape optimisation of ONERA M6 wing. Can you please send me the CAD geometry of this wing that I can upload in ICEM. If possible can you also send me some simulations of M^ wing Regards, Malik |
January 23, 2013, 08:42 |
Malik
malik
Rep Power: 14 |
Hi Aurélien,
I am in severe need of ONERA M6 wing 3D mesh. i need both coarse and fine mesh that i can open in ICEM and then run simulations in Fluent. Can you plz send it to me on s.malik.eng@gmail.com |
M6 ONERA Wing profile | Cyril A. | Main CFD Forum | 18 | December 31, 2016 15:59 |
Looking for data of ONERA M6 wing | Chih-Hao Chang | Main CFD Forum | 2 | May 29, 2009 12:49 |
Onera M6 wing | sheetal | Main CFD Forum | 9 | May 28, 2009 12:30 |
extrapolation in MUSCL scheme | Chandra | Main CFD Forum | 6 | February 14, 2007 12:21 |
Onera Wing Wall function? | Dianhong | Main CFD Forum | 0 | November 21, 2003 21:19 |
