Symmetry in Fluent: Force-Y not equal to zero? |
April 12, 2010, 11:28 |
Edu
Rep Power: 17 |
Hi all!
I am simulating a 3d rear wing: And I have a problem or question with the symmetry boundary condition. I put the ZX plane as a Symmetry in Fluent (it is the symmetry plane of the wing), but when I simulate it, the value of Force in the Y axis is not equal to zero. Why? What is the geometry that is simulated? Complete wing or only a half of it? Thanks! Regards! -Edu- |
April 13, 2010, 07:30 |
Maxime Perelli
Rep Power: 41 |
Only the half of your model is computed. That's why you don't get zero at F-Y.
In memory of my friend Hervé: CFD engineer & freerider |
April 13, 2010, 12:03 |
Edu
Rep Power: 17 |
Hi -mAx-!
Thanks for your answer! Regards -Edu- |
August 9, 2023, 07:06 |
DRS
Which sense has the symmetry, if the model is calculated just half?
This means, you would also have to double the other forces. |
symmetry boundary condition in fluent | v_h_memar | FLUENT | 8 | May 1, 2019 00:08 |
UDF in Fluent | Andrew | Fluent UDF and Scheme Programming | 5 | March 7, 2016 03:38 |
Fluent jobs through pbs | ibnkureshi | FLUENT | 5 | June 9, 2011 13:43 |
Force report when using symmetry | Tudor Miron | FLUENT | 3 | April 2, 2004 16:49 |
Symmetry in Gambit?Help! cant see it in fluent | Puck | FLUENT | 4 | August 6, 2002 07:56 |
