symmetry boundary condition in fluent
Old   April 12, 2010, 03:54
Default symmetry boundary condition in fluent
Vahid Memar
v_h_memar is on a distinguished road
Hi
I want analysis a 3D fan in fluent but I want to model only one of two blades(the fan has two blade) , but when I use symmetry boundary condition, the solution does not converge. and I think it is logic because in fan we do not have symmetry condition , rather we have rotation axis , but in 3D we can not use axis condition. is any body can help me ?
v_h_memar is offline   Reply With Quote
Old   April 12, 2010, 08:16
Max
coglione is on a distinguished road
As you already realized, there is no symmetry condition for your given flow problem. Maybe a rotationally periodical boundary condition can be utilized to reduce the computational domain to a 180° segment?
cheers
coglione is offline   Reply With Quote
Old   April 12, 2010, 08:57
Vahid Memar
How can do rotationally periodical boundary condition on my problem ?
Old   April 12, 2010, 10:26
Max
It depends on the periodicity of your actual geometry and flow field. Have a look at the UserGuid chapter 7.15 whether periodic bc are applicable for your problem. If so, you have to obey some rules when generating the mesh in gambit (mesh hardlink).
cheers
Old   April 14, 2010, 04:45
Default Fluent Err
Vahid Memar
Hi Cogline
I do hardlink mesh and after that exported mesh, but when I import in fluent , we have an Error , can you guess what is the problem ?
you can receive mesh file and gambit file(dbs) from below link.
http://ifile.it/voabcxt/Gambit.rar
thanks
Memar
Old   April 14, 2010, 05:06
Max
Which error?
Old   April 14, 2010, 05:13
Vahid Memar
Originally Posted by coglione View Post
Which error?
can you download file from bellow link ?
Old   August 30, 2012, 10:08
Default boundary condition (symmetry vs periodic doubt)
hhh
kunar
hhh is on a distinguished road
Dear friends,
i am doing 3D wing analysis, i have doubt on boundary conditions in fluent ie both symmetry and periodic, anybody have the answer please let me know briefly,for what kind of purpose to use symmetry & periodic boundary conditions, please tell any example with problem.
hhh is offline   Reply With Quote
Old   May 1, 2019, 01:08
Default Hi dears Friends
tea restiana
tea restiana is on a distinguished road
I simulate 3d seawater in the case of dispersion thermal analysis of the power plant cooling water using ansys fluent, the geometry and namely boundary conditions that I modelled is shown in the figure bellow. In modelling physical models used k-epsilon and active energy. the material used is only one phase, namely water. Temperature normal seawater set 30℃ and temperature discharge outlet 37℃.The boundary conditions are discharged outlets, ambient inlet, outlet, ocean, seabed and seashore. The discharge outlet is the discharge area of the cooling water power plant modelled as an inlet velocity with a velocity of 1.71 m / s and a temperature value of 37℃, the ambient inlet boundary condition is modelled as an inlet velocity at 0.4 m / s and a temperature value of 30℃.Outlet modelled as outflow.Seabed and seashore as a wall.
For ocean boundary conditions I model as symmetry. what I want to ask, in my case is it okay if I model ocean as symmetry? Can anyone explain that? Or do I need to use other boundary conditions?
tea restiana is offline   Reply With Quote
Wind turbine simulation Saturn CFX 60 July 17, 2024 06:45
Symmetry Boundary Condition Noname Main CFD Forum 8 February 20, 2014 17:48
How to use a solution as an inlet boundary condition in another problem in fluent geryes FLUENT 0 February 25, 2010 17:32
how to apply cauchy type boundary condition in fluent aksrun FLUENT 0 January 30, 2010 09:07
fluent Boundary condition of supersonic flat plate Mechal FLUENT 0 December 16, 2005 17:07
