April 8, 2010, 05:57 |
inverse heat transfer problem
siva
Dear all
I wish to solve a 1D heat conduction problem inside a copper block. the bottom end has constant heat flux boundary condition and the top end has a variable heat transfer coefficient. i have measurement data for transient temperature profile at two interior points. How do i estimate the transient heat transfer coefficient? I understand there is no direct option available in fluent.but even if I am supposed to write UDF what is the approach and how to go about the same? other wise are there any open source codes available for solving inverse problems? regards Siva |
January 29, 2012, 09:23 |
#2 | |
Jack
Rep Power: 16 |
i have the same doubt as you. Take a look at http://www.cfd-online.com/Forums/mai...-possible.html . Rogerio. Quote:
February 19, 2019, 03:06 |
alireza javadpour
Rep Power: 7 |
hi all, i have a square with heat generation rate inside that, i have three boundary conditions with constant temperature, but i dont have heat flux from one of walls, i want to simulate this problem in Fluent, could you please any one explain me??
February 19, 2019, 09:45 |
#4 | |
Lucky
Rep Power: 66 |
You need to know all your boundary conditions. |
February 19, 2019, 15:15 |
alireza javadpour
Rep Power: 7 |
i have three wall with constant temperature 300k that is determined but the output heat flux from one wall is unknown, i have temperature within the enclosure that is 400k.
February 20, 2019, 10:33 |
Lucky
Rep Power: 66 |
You need to know all your boundary conditions. End of story.
February 22, 2019, 07:00 |
Alexander
Rep Power: 34 |
you should modify your domain
for example add solid attached to 4th wall or some fluid zone, depending on your case so you will get other boundaries with known boundary conditions best regards |
Wall heat transfer coefficient (HTC) problem | Mohamed khamis | CFX | 1 | January 16, 2010 00:12 |
Heat transfer problem | menorka | OpenFOAM | 1 | November 26, 2009 05:22 |
How can I increase Heat Transfer at Domain Interf? | B.Simon | CFX | 3 | October 28, 2008 19:53 |
heat transfer problem. | vipin | CFX | 2 | July 18, 2006 11:05 |
Convergence in a conjugate heat transfer problem | dp | Siemens | 6 | June 9, 2006 01:53 |
