Negative Volume - TET Mesh Compression
Old   April 6, 2010, 06:42
Unhappy Negative Volume - TET Mesh Compression
Chester
ChesterP is on a distinguished road
Hi everybody,
I'm doing 3D in-cylinder simulations.
When the piston head is moving from BDC to TDC and reaches the cut-off distance I first have skewness issues and then at around 297-298° negative volumes appearing.
So there are problems only for the compression of the tetrahedral mesh.
I tried to vary :
- Spring Constant Factor between 0 and 0.5;
- Boundary Node Relaxation between 0.2 and 1;
- Convergence Tolerance between 0.001 and 0.0001;
- Number of Iterations between 20 and 100;
I remesh at each time step with a crank angle step of 0.05°.
Thanks in advance
ChesterP is offline   Reply With Quote
Old   April 6, 2010, 07:17
李逾
yubaibai88 is on a distinguished road
Originally Posted by ChesterP View Post
Hi everybody,
I tried to vary :
Thanks in advance
hi chesterp:
I't so glad to see you again
maybe you can try to change the parameter in remeshing like min length scale and max length scale.
do not set them too much adjacent to the min and max length scale in your domain
yubaibai88 is offline   Reply With Quote
Old   April 10, 2010, 02:34
李逾
Hi everybody,
I tried to vary :
Thanks in advance
hi chesterp:
I think I've find out where your problem is.
but first I want say sorry for the previous answer to you for it's not right.and second is that I can only demonstrate it in 2D simulation.
now it's my opinion:
in the cold flow simulation,I follow all what the tutorials told me to do without set the piston stroke cutoff 0.01m.when start mesh motion,I gained the mesh as prestent in picture 1.it is obviously that the mesh adjacent to the cylinder boundary is very bad.
then I creat a new dynamic mesh zone.cylinder-side-tri,which is the boundary of the triangular zone.after mesh motion,the mesh I gained is showen in picture 2.it rapidly improved after setting a new deforming boundary zone.
note that the motion I defined is from TDC to BDC.
after the pistion reach BDC.I delete the deforming boundary zone defined in TDC.then start mesh motion,finally negative volume appears when piston reach the cutoff distance.
that's all I do to experiment the appearing of negative volume.sorry to say I do it in 2D simulation,but boldly can I guess where your problem is.maybe it is because you did not define a deforming boundary zone which is the boundary of your tetrahedral zone.fluent assumes it wall if you don't define it.when the piston moving up,the boundary nodes are compressed and finally negative volume appears.
hope it help
Old   April 11, 2010, 03:05
Chester
Originally Posted by yubaibai88 View Post
hi chesterp:
hope it help
Thank you very much for your help.
I already defined the wall as deforming for my tetrahedral mesh so it is not the issue I think
When the piston reach the cutoff distance and that the tetrahedral mesh should be then smoothed and remeshed it is like the process is not done quickly enough compared to the motion of the piston. Hence negative volumes are appearing. I already chose a small crank angle step (0.05°) and remeshed at each step. I will try to run a simulation with a smaller rotation speed of the engine and I will tell you what.
Have a nice day
Old   April 11, 2010, 03:49
李逾
Have a nice day
all right
if the negative volume still appears,sent your cas/dat to me.I will try to check.
good luck
dynamic, remeshing, smoothing
Gambit problems Althea FLUENT 22 January 4, 2017 04:19
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 09:54
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 07:42
Interpolating volume data onto quad surface mesh N.R. CFX 6 June 7, 2007 09:15
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
