April 1, 2010, 16:12 |
change particle properties using udf?
Rep Power: 16 |
HI all,
In modeling particle spraying, I try to change some of the particle's properties during flight when certain conditions are met. I wrote a udf using DEFINE_DPM_PROPERTY as in the example shown in the udf manual, but then found out that in the dialogue box for setting particle material, only a few properties allow udf (i.e. have the "user-defined function" option in the drop-down list), and others (like the thermal conductivity) do not have this option. So if I need to change the particle's thermal conductivity, what should I do? thanks in advance! ljp |
Using UDF to alter particle size | Tumppi | Fluent UDF and Scheme Programming | 7 | February 28, 2019 09:27 |
Add Mass to a Particle with UDF (DPM) | sega | Fluent UDF and Scheme Programming | 6 | October 24, 2013 23:14 |
Problem with getting the particle position using UDF | Ananth Pai | FLUENT | 0 | January 17, 2010 02:11 |
HELP! HELP! For udf of particle body force!!!! | zhaoh | FLUENT | 0 | February 5, 2007 05:10 |
Problem in UDF about particle size distribution | fpingqian | FLUENT | 0 | February 25, 2005 02:48 |
