how to treat the rotating zone in multiple reference frame (MRF)
Old   March 31, 2010, 13:18
Default how to treat the rotating zone in multiple reference frame (MRF)
Dongzi Wei
Jiuan is on a distinguished road
I am studying the Tutorial 10 in Fluent, which is "Using multiple rotating reference frames". The whole simulation domain is divided into three fluid zones. The middle zone is the rotating zone, and it is attached to a moving reference frame in "cell zone conditions". I don't understand why the rotating fluid zone should be attached to a rotating reference frame. Can I do this way: the whole domain is ketp as one domain, I mean it is not divided into three zones, and I just define the moving boundary conditions for the surfaces of the blade, which is wall-7 in this tutorial. Thanks.
Jiuan is offline   Reply With Quote
Old   May 10, 2010, 15:17
Jade M is on a distinguished road
In general, if the rotating fluid zone is solved in a stationary reference frame, then the problem becomes transient and multiple meshes need to be read in throughout the simulation. As the mesh becomes too deformed, then a new mesh needs to be used. For a more automated choice, remeshing can also be utilized. The advantage of the moving reference frame is that the problem becomes steady and a single mesh can be used throughout the simulation. I hope this is helpful.
Jade M is offline   Reply With Quote
Old   May 21, 2010, 05:06
Default Re
Susan YU is on a distinguished road
Hi, Jade,
I'm making a calculation by using the rotating reference frame, but I found I cannot make the heat transfer calculation on the rotating wall. Do you have some suggestion on this type of calculation?
Thanks
Susan YU is offline   Reply With Quote
Old   May 24, 2010, 11:42
Hi Susan, I'm sorry as I do not know how to do this. I would suggesting posting a new thread and maybe someone will be able to answer. Good luck!
Old   May 24, 2010, 22:58
Thanks, I will do that
Wind Turbine + MRF (Multiple Reference Frame) abolfazl FLUENT 8 May 28, 2013 08:44
question about governing equation in CFX using rotating/non rotating reference frame rystokes CFX 0 January 12, 2010 07:14
Error with Wmake skabilan OpenFOAM Installation 3 July 28, 2009 01:35
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
G95 + CGNS Bruno Main CFD Forum 1 January 30, 2007 01:34
