combusting particle definition
Old   March 29, 2010, 14:18
Default combusting particle definition
bjcfd is on a distinguished road
Hi! I have a quick question about defining combusting particles in the DPM model. If wet combustion is turned on, when defining the material properties of combustion particles, should the fractions of volatiles/combustibles on dry basis or wet basis? And the devolatilization temperature, should it be the water boiling point temperature or the temperature for the onset of particle devolatilization reaction?
Thanks in advance!
bjcfd is offline   Reply With Quote
Old   March 29, 2010, 17:26
sega's Avatar
Sebastian Gatzka
sega is on a distinguished road
You would suppose (meaning I don't know for sure) that is should be based on wet conditions...
Schrödingers wife: "What did you do to the cat? It's half dead!"
sega is offline   Reply With Quote
Old   March 30, 2010, 14:27
Many thanks for the reply. Any more comments on this?
Old   July 19, 2012, 06:37
Unhappy modelling combustion fluel
Udayana
made is on a distinguished road
Hai everybody, i have problem how to modeling temperature combustion biomass fuel using fluidized bed? Please help me
made is offline   Reply With Quote
Old   July 20, 2012, 06:02
Alex
a.m. is on a distinguished road
Send a message via ICQ to a.m.
Thanks in advance!
If wet combustion is turned on, you should use volatiles/combustibles on dry basis. please see eq. 16-134 Fluent Theory guide. Liquid fraction (in wet combustion tab) should be defined as volume fraction, volatiles/combustibles (in materials tab) - as mass fraction.
If you hesitate, check the mass balances.
Regards a.m.
a.m. is offline   Reply With Quote
combusting particle, dpm
DPM UDF particle position using the macro P_POS(p)[i] dm2747 FLUENT 0 April 17, 2009 02:29
particle loading definition Shuo Main CFD Forum 0 April 16, 2008 00:58
Particle track files Sankalp CFX 1 August 26, 2004 00:25
the separated particle temperature in cyclone mkuswadi FLUENT 0 December 17, 2003 09:25
Iclude particle diameter effect in wall? yueroo FLUENT 0 April 14, 2001 04:56
