VOF - Patching
Old   March 29, 2010, 10:10
Default VOF - Patching
SK
friends.sk is on a distinguished road
Halo,
I am working with VOF in 3D.
In VOF patching is required for secondary phase. In case of simple geometries its works fine with the dimension. When we have some triangular geometry, How can we patch the secondary phase?
Sketch of the geometry looks like this..
regards
SK
friends.sk is offline   Reply With Quote
Old   March 29, 2010, 10:12
sega's Avatar
Sebastian Gatzka
sega is on a distinguished road
Sorry to ask, but what is 'patching'?
Schrödingers wife: "What did you do to the cat? It's half dead!"
sega is offline   Reply With Quote
Old   March 29, 2010, 10:16
SK
In VOF model, while initialising we need to fill the secondary phase in the specific region and the rest with primary phase. This can be done by marking some region using adapt panel. and then using solve->initialise--> patch.
Old   March 29, 2010, 17:20
sega's Avatar
Sebastian Gatzka
Sorry, I'm out. I have made experience with VOF and its theoretical background using OpenFOAM. Your question is too FLUENT-related.
I'm afraid I can't help you there.
Old   March 31, 2010, 11:42
Martin
Martin D! is on a distinguished road
doesn't Fluent mark the cells necessary if u just put in the coordinates? I suppose so ...
Martin D! is offline   Reply With Quote
Old   March 31, 2010, 13:57
Philipov's Avatar
Svetlin Filipov
Philipov is on a distinguished road
Define the region as a separate volume and patch it
Philipov is offline   Reply With Quote
Old   April 2, 2010, 02:56
Smile VOF - Patching
sunqiang
matthewsun is on a distinguished road
You can first set a region in Adapt->region in fluent ,you can either set a quad region or circular one using the input coordinate . Then then you can patchthe after initialization , in the patch panel choose the second phase and set the value to 1 or so. you can check it using display->contour ->phase fraction
Hope it helps
matt
matthewsun is offline   Reply With Quote
UDF Defining VOF Free Surface at Outlet Alex Fluent UDF and Scheme Programming 13 August 8, 2012 17:50
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
VOF UDF FOR PATCHING SINUSOIDAL FREE SURFACE beginner FLUENT 1 September 10, 2007 03:16
VOF Patching fluids at an angle? Brian FLUENT 0 October 26, 2005 21:58
Difficult BCs about Freesurface Simulation by VOF Yongguang Cheng FLUENT 0 September 19, 2003 08:39
