Question about reference values --> Area (multi element wing)
Old   March 28, 2010, 09:39
Default Question about reference values --> Area (multi element wing)
smith
Zweeper is on a distinguished road
Hello everybody!
I have a question about the reference values for an 3D multi element rear wing.
First of all, if i analyse a single element airfoil under different angles of attack, my reference area of my wing is always the chord-line times the length of the airfoil right? doesn't matter which angle of attack my airfoil has?!
But what happens in the case of an multi element rear wing? (attachment)
my logical thoughts say me that i just have to summarize all the single element areas by calculating the single elements as described above.
Is this right or i am doing an mistake there?
Kind regards!
Zweeper is offline   Reply With Quote
Old   March 28, 2010, 11:42
Jouke de Baar
jack1980 is on a distinguished road
A common choice is the planform area. This is the area of your wing projected on the ground when the wing is in horizontal position. In this definition it does not depend on AoA.
You might use: report > projected areas
Good luck!
jack1980 is offline   Reply With Quote
Old   March 28, 2010, 11:46
smith
so, if my wing is in horizontal position where this is the x direction, you mean i should use the projected area in x direction?
Old   March 28, 2010, 12:16
Jouke de Baar
Hi, that is correct, only to my understanding your projection should be in the z-direction. (Or in the y-direction for a 2d case.)
So for a 3d case let fluent do the projection along the z direction. Make sure to have the resolution small enough.
For a 2d case simply take the difference between the x-coordinates of the first leading edge and the last trailing edge of your wing.
Old   March 28, 2010, 12:22
smith
hm, if my chord-line is in the x direction,
the thickness is in the y direction
and the depth is in the z direction
i thought i should chose the y direction for the 3d case?
Old   March 28, 2010, 12:23
Jouke de Baar
your right
Old   March 28, 2010, 12:25
smith
okay, thanks a lot!
Old   March 28, 2010, 12:29
Jouke de Baar
Good luck!
Cp values for F3 rear wing for a 4th year thesis Joe Bryant FLUENT 4 June 11, 2010 00:40
compile error about FJMPI chiven OpenFOAM Installation 11 March 31, 2010 07:27
question about governing equation in CFX using rotating/non rotating reference frame rystokes CFX 0 January 12, 2010 07:14
CFX Solver Memory Error mike CFX 1 March 19, 2008 08:22
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 13:02
