flickering display window in new Fluent version 12.1
Old   March 25, 2010, 13:29
Default flickering display window in new Fluent version 12.1
Ivan
ivanbuz is on a distinguished road
The display window is always flickering, making it almost impossible to work with. These guy try to push out new version frequently to make more money, but they always cause some annoying bugs in the new version. The one is specially unbearable.
I hate it!
ivanbuz is offline   Reply With Quote
Old   March 25, 2010, 13:45
sega's Avatar
Sebastian Gatzka
sega is on a distinguished road
I hate it!
Not with me. What system & configuration are you using?
Schrödingers wife: "What did you do to the cat? It's half dead!"
sega is offline   Reply With Quote
Old   March 25, 2010, 13:50
Ivan
The fluent is installed on the Linux system in high performance computing center, I use Xming and Putty to run it from my PC.
I did not have this flickering problem with the older version 6.3.26
Old   March 25, 2010, 13:54
sega's Avatar
Sebastian Gatzka
I experienced the same problem with Xming.
You should try to use Exceed instead. This leads to far better results.
Old   March 25, 2010, 17:21
Ivan
Sega,
Thanks a lot! Using Exceed, the display window still flickers, but it is much better than using Xming.
You said you do not have problem with it. How do you run it?
Old   March 26, 2010, 04:05
sega's Avatar
Sebastian Gatzka
Sega,
Directly from my local Windows 7 machine ;-)
I suppose the result with Exceed is the best you can get.
Display velocity vector and contour in the same window lalula2 FLUENT 2 August 24, 2009 09:11
Saving *.cas and *.dat from Fluent parallel version Pfalcon FLUENT 2 August 14, 2009 15:57
How to display three isothermal line in FLUENT? marqueen FLUENT 5 March 28, 2008 08:09
FLUENT Version Mis-Match Discrepancy asd Main CFD Forum 0 April 19, 2007 05:58
Fluent Parallel/Serial version..jump in residuals Sandeep Abhyankar FLUENT 4 January 10, 2000 10:57
