VOF Volume fraction in Velocity inlet
Old   March 18, 2010, 09:40
Default VOF Volume fraction in Velocity inlet
amélie ruelle
aruelle is on a distinguished road
Hello
I am using a VOF model for the simulation of a diphasic flow entering a pipe and then spilled in a tank. The entry of the diphasic flow is defined as a velocity inlet. The volume fraction of the velocity inlet in fixed to 0,3. Convergence is ok. Moreover, i saw different works where the volume fraction of the velocity inlet is different from 1 or 0.
Nevertheless, i read in an Ansys document that for velocity inlet, only one phase can enter; therefore, only one phase can have the inlet volume fraction set to 1 and nonzero inlet velocity.
So, can somebody help me about this? Is it allowed and physically correct to impose a volume fraction of 0,3 to a velocity inlet with the vof model?
Thank you very much for your help,
Amélie
aruelle is offline   Reply With Quote
Old   March 18, 2010, 12:53
sega's Avatar
Sebastian Gatzka
sega is on a distinguished road
Originally Posted by aruelle View Post
Hello
Amélie
For a volume fraction you will need a volume, where a boundary is a face.
So this does not make sense.
You want to set up 30% of the inlet with phase one and 70% of the inlet with phase two? Am I guessing right?
I would split up the inlet into two (30%/70%) and define the VOF-variable to 0 at the one and 1 at the other.
Schrödingers wife: "What did you do to the cat? It's half dead!"
sega is offline   Reply With Quote
Old   May 10, 2024, 11:17
Default VOF Volume fraction in Velocity inlet Phase Problem
AA
kkaptan is on a distinguished road
I hope this message finds you well. I am reaching out to seek assistance regarding a challenge I am facing while trying to calculate the free surface elevation in Fluent.
My aim is to accurately determine the free surface elevation when a wing moves over the free surface. Initially, I attempted this by utilizing the "Open Channel Flow" option. However, despite setting the pressure inlet boundary conditions, I encountered an issue where the free surface did not deform as expected, even though the iterations proceeded without any apparent problems. I have attached a screenshot illustrating this problem for reference. In this particular simulation, the velocity (U) is set to 10 m/s, and the ratio of the water depth to the wing's chord length (h/c) is 0.2.
Subsequently, I modified the inlet boundary condition to a Velocity inlet. However, I found that there was no option available to define the free surface level in this configuration. My attempt to address this by using a region and patching it after initialization did not yield the desired results, as there still remained a small area where air was present, as evident from the attached screenshot.
In an effort to resolve this issue, I experimented with using two different inlets, namely "inlet_air" and "inlet_water." Unfortunately, this approach resulted in the analysis diverging. I suspect that I may have made an error in defining the boundary conditions.
I would greatly appreciate any insights or guidance you could provide on this matter. Your expertise and assistance in navigating through this challenge would be invaluable to me.
Thank you very much for your time and consideration. I look forward to hearing from you soon.
kkaptan is offline   Reply With Quote
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Multi phase Volume fraction at inlet F S CFX 1 April 11, 2011 22:08
Volume Fraction vs Velocity???? HAR FLUENT 2 May 30, 2006 17:30
VOF & initial volume fraction Mark FLUENT 2 April 26, 2006 19:18
UDF problem : inlet velocity in cyl. coord. system Jongdae Kim FLUENT 0 June 15, 2004 12:21
