boundary condition for straight 3D open chnannel
Old   March 15, 2010, 03:47
Default boundary condition for straight 3D open chnannel
Mrityunjay sahu
moon1234 is on a distinguished road
I am setting up a problem on 3D straight open channel flows........can any one suggest me the boundary conditions to be imposed during meshing in Gambit?
moon1234 is offline   Reply With Quote
Old   March 15, 2010, 06:25
Vincent Meertens
vmeertens is on a distinguished road
Send a message via MSN to vmeertens
I'm also doing a case with 3D open channel.
For inlet and outlet i use: Pressure Inlet and Pressure Outlet.
For your plate you should use wall. (in fluent this will be a stationary wall)
If you have a brick (flow volume) then your BC for the rest of the sides should be wall (in fluent i define them as moving walls with the same speed as the fluid)
Hope this helps.
vmeertens is offline   Reply With Quote
Old   March 15, 2010, 06:39
Philipov's Avatar
Svetlin Filipov
Philipov is on a distinguished road
BC depends on what you know... inlet velocity, Pressure inlet, mass flowrate and so on.... we do not know that information....
Using Pressure inlet and Pressure outlet assume compressibility of the fluid that is not known also... BC must be set to property that you can compare to any reference value...... rearrange the question and ask again when you can give more details and have more information about the task....
Philipov is offline   Reply With Quote
Old   March 15, 2010, 07:41
Mrityunjay sahu
wat about freesurface...........wat would be the BC for top surface
i have two option in it............
1. To apply pressure inlet
2. moving wall
Old   March 15, 2010, 07:46
Vincent Meertens
Hey,
Philipov is right, i replied to soon...
I assumed it was just water and air with a constant inlet speed.
The free surface doesn't need a BC (if i'm correct ) This is done in Fluent and not in Gambit.
Old   March 15, 2010, 07:57
Mrityunjay sahu
yeah buddy this is done in fluent after completion of meshing
Old   March 15, 2010, 07:59
Mrityunjay sahu
but about boundary condition to free surface
How exactly the "pressure outlet" bdry condition compute properties on the boundary? yating9901 FLUENT 3 June 28, 2010 13:26
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
Open boundary condition norman1981 OpenFOAM Pre-Processing 0 September 24, 2008 10:09
Slip boundary condition what is inside normunds OpenFOAM Running, Solving & CFD 2 June 4, 2007 07:45
Pressure Boundary Condition Matt Umbel Main CFD Forum 0 January 11, 2002 11:06
