Modelling 2d sails with masts in Fluent
Old   February 28, 2010, 13:52
Default Modelling 2d sails with masts in Fluent
panosna is on a distinguished road
Hello everyone!
I am doing my individual project in my university and the subject has to do with the airflow around sails with masts.
The software I use is FLUENT.
I wonder if anyone could suggest which model should I use and any other important parameters.
After some research, I saw that some suggest the Spallart-Allamaras model and others sugest the k-ε model for sails with masts.
I am a bit confused.
In order to find out myself which should I use, I am testing them on some axial fan blades, because I have some experimental data for these, in order to compare my results. The reason I am testing the blades, is that the geometry is about the same as the sail.
If anyone could suggest what should i use for ths sails with mast, please reply.
Thank you.
panosna is offline   Reply With Quote
modelling wall thickness coupling (like fluent) in cfx suryawanshi_nitin CFX 3 April 13, 2009 02:25
Plsama modelling in FLUENT Homayoon FLUENT 1 March 24, 2009 12:24
Problems in lauching FLUENT Lourival FLUENT 3 January 16, 2008 17:48
Need Help on Fluent Modelling Laminar on BluffBody ary Main CFD Forum 1 May 19, 2005 06:59
multi phase modelling in fluent naren FLUENT 1 January 25, 2005 13:31
