CD nozzle contour design for 2D analysis
Old   February 28, 2010, 12:33
Default CD nozzle contour design for 2D analysis
rattletop is on a distinguished road
hi all,
i am doing a project on analysis of flow through CD nozzle. i am planning to design the contour in Catia & mesh in gambit n solve using fluent. But How do i plot the 2d contour for the nozzle.(bell shaped) for a shock-free isentropic flow? has any1 plotted the 2d nozzle before? if so pls help..
rattletop is offline   Reply With Quote
Old   February 28, 2010, 15:39
Shamoon Jamshed
Shamoon Jamshed is on a distinguished road
Send a message via Skype™ to Shamoon Jamshed
Originally Posted by rattletop View Post
hi all,
Hi
This is not a big issue especially if u wana do in 2D. Ther may be two ways
1) Remain the profile (outer) in Catia and export it as IGES. Then import this IGES in Gambit
2) If you have coordinates available in x, y or x, R format then copy them to a excel. Her you will get them in column format. Then copy the two (or three columns in case of 3D) to a notepad file. the first row will however contain the number of points (above first column) and edges above (2nd column). Then in Gambit import it as an ICEM input. Hope this will help
Shamoon Jamshed is offline   Reply With Quote
Old   March 1, 2010, 08:32
hey shamoon thanks for the reply. i do know about importing iges but how do i plot the contour in catia? i dont have x, y co-ordinates for the 2d model(bell shaped). Should i use some approach like Method of Characteristics to design it? I dont know much about MOC approach..just know a bit.
Old   March 1, 2010, 09:35
Default CD Nozzle profile
Shamoon Jamshed
Hi
Ok your issue is a bit different, I havent desgined any nozzle myself so yes I think u need MOD to desing nozzle profile. Better see Anderson book compressible fluid flow
Regards
Old   March 29, 2010, 17:21
Michael Handschuh
mhandschuh is on a distinguished road
hi all,
If you're doing a 2D planar nozzle the MOC equations break down into algebraic equations. If you're trying to do an axially symmetric nozzle you're going to have to use finite differences with MOC. Either way you would want to write a piece of code to solve for the nozzle shape.
To do this use the MOC equations along the characteristics and use a mass balance at the nozzle wall.
mhandschuh is offline   Reply With Quote
Old   January 25, 2011, 12:39
Smile cd nozzle
aditya
hello2apsingh is on a distinguished road
hi all,
hi to all if u want then i can help u but i need little favour from you.
for more details mail me at hello2apsingh@gmail.com
hello2apsingh is offline   Reply With Quote
ansys, cfd, fluent, gambit, nozzle
Axisymmetric nozzle design using the MOC Will James Main CFD Forum 22 May 24, 2012 02:25
compressible flow in a counterflow nozzle d.vamsidhar FLUENT 0 November 24, 2005 02:45
Analysis of propeller with nozzle Ammu FLUENT 0 July 1, 2005 09:00
Industrial Nozzle Design Bharath Main CFD Forum 0 December 4, 2002 18:14
Info: Short Course On Thermal Design of Electronic Equipment Arnold Free Main CFD Forum 0 August 10, 1999 11:18
