Video from case and data files
Old   February 25, 2010, 06:55
Default Video from case and data files
Davide Girardini
girino is on a distinguished road
Hi all,
I'm working on an unsteady simulation with XP. I've saved my "Case and data" files for each second, my time step is 10e-3, so I have about 300 "Case and data" files. Totally I have about 300 seconds. How can I make an animation of these 300 seconds? Should I save for each "case and data" file a .jpeg and use a program to assemble all those images in a video?
Thank you very much
girino is offline   Reply With Quote
Old   February 25, 2010, 07:57
Thanh
thanhndb is on a distinguished road
As I know for the unsteady simulation you should make mpeg video file as follows:
Solve/animate/define/
Hope to share experience on CFD
Regards,
Thanh
thanhndb is offline   Reply With Quote
Old   February 25, 2010, 08:14
Eric
hubidoo is on a distinguished road
Calculation activities for each time step
e.g:
/di/set/picture/driver jpeg /di/set/cont/surface A () /di/view/restore-view B /di/cont velocity 0 1 /di/save-picture "/home/picture.jpg"
hubidoo is offline   Reply With Quote
Old   February 25, 2010, 08:15
Davide Girardini
That is the procedure if you have only one "case and data" file. I want assemble 300 different "case and data" files. Thanks for reply Thanh.
@hubiloo
What does that piece of code do? How can I assemble?
Old   February 25, 2010, 08:40
Eric
with calculation activities --> create/edit execute commands you can define different kinds of activities for each time step or iteration...
The given code is a text command (check out the help), which is execute each time step...
Old   February 25, 2010, 10:18
Davide Girardini
I do not want iterate, I want make an animation. Can you do that with only case and data files?
Old   February 25, 2010, 10:36
Eric
Maybe there is a better way, but in my opinion you have to calculate again...
with /display/save-picture/"folder/file.jpg" you can take pictures of every time step. After your simulation, put all pictures to a movie together.
Old   February 26, 2010, 05:11
Davide Girardini
Ok, thanks.
Old   March 26, 2010, 10:05
Elahe
ekakavand is on a distinguished road
Hi Hubidoo
but display menu does not have "save pictures" what do you mean?
i tried to do it from execute commands in solve menu but i could not do it correctly,
please help me, i wanna save window of contour each several time step.
thanks in advance
elahe
ekakavand is offline   Reply With Quote
Old   March 29, 2010, 03:41
Philipov's Avatar
Svetlin Filipov
Philipov is on a distinguished road
Use Tecplot.... there you can make good animation
Philipov is offline   Reply With Quote
getting data from case and data files mkrao FLUENT 2 February 10, 2009 01:11
fluent case n data files not exporting to tecplot krishna FLUENT 2 February 18, 2007 00:24
How to update polyPatchbs localPoints liu OpenFOAM Running, Solving & CFD 6 December 30, 2005 18:27
Are Case and Data files enough? Zhengcai Ye FLUENT 6 January 8, 2004 05:02
Structure of case and data files Frederic Nicolas FLUENT 1 August 4, 2000 12:54
