Cooling effect of water flowing on the rooftop
Old   February 19, 2010, 22:57
Default Cooling effect of water flowing on the rooftop
sunnyzai is on a distinguished road
I am doing a simulation on flowing water on the rooftop of a model which is 15cm (H)x 30cm (L)x 52cm (W), to monitor the heat transfer of the roof and also the temperature distribution in the model.
I try to built my simple model using gambit by creating a 2D rectangular box with another face of 1cm height as my flowing water:
________________ --> water surface
________________ --> water outflow
|.....(inner air)...... |
|.........................| --> rectangular box with a small opening for ventilation (pressure outlet)
(I set my roof plate as a wall boundary which is hot plate, producing heat to the inner air.)
After that, i try to import my mesh into Fluent (in Ms Window), but the warning come out as follow:
Warning: Both outflow and pressure boundaries are present in the
domain. This is an incompatibility and solution cannot
proceed until this is fixed.
So, what should i set for the next in order to fix the warning above.
Also,
1. Since i have two phase, which multiphase should i use, VOF? (but it cannot simulate the heat transfer problem)
2. Is it one of the open channel problem?
Hope someone can help me... Thanks in advance
sunnyzai is offline   Reply With Quote
Combustion with water cooling Hlynur Thorkelsson FLUENT 2 March 21, 2007 15:13
water flowing in a container GaryWang CFX 4 June 29, 2005 10:26
Make a simulation of water flowing into a vase !?? Vu Trinh Tuan CFX 7 April 6, 2005 15:23
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
uptodate water distribution network fredius,magige,tanzanian,(e.a) Main CFD Forum 0 January 27, 2002 08:10
