real gas simulation in ejector for supersonic flow
Old   February 19, 2010, 06:04
Default real gas simulation in ejector for supersonic flow
rahul
rahul_bhad1 is on a distinguished road
I were doing simulation of real gas for supersonic ejector. But, the following message is appearing while starting the iterations.
Error: REFPROP_error (202) from function: tprho (density)
[TPRHO error 202] liquid iteration has not converged for T = NaN K, P = 0.20000E-01 MPa, rho (last guess) = NaN mol/L, compositions = 1.00000
Error Object: ()
The boundary conditions are given as follows -
pri. flow inlet - pressure inlet 400600 Pa, total temp. 78 C
sec. flow inlet - pressure inlet 39990 Pa, total temp.8 C
pressure outlet - pressure outlet 40000 Pa, backflow total temp. 35 C.
Real gas used is R141b.
Can anyone help me?
rahul_bhad1 is offline   Reply With Quote
Old   March 31, 2015, 22:12
Amjad Farah
amjadfirst is on a distinguished road
I had that happen to me a few times under different conditions. Changing the mesh could help (refining), but what worked for me is changing the under relaxation factors. drop them by a lot and see what happens.
amjadfirst is offline   Reply With Quote
how to set up high temperature gas turbine flow simulation? adam2008 CFX 1 July 22, 2009 19:33
compatibility problem of UDF on LINUX manu FLUENT 4 December 19, 2007 05:58
Pressure boundary condition and real gas Pifou FLUENT 0 July 19, 2005 12:42
Transient natural gas flow description Leila FLUENT 0 November 29, 2003 17:06
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 13:19
