negative volume error
Old   February 18, 2010, 10:44
Question negative volume error
Amrit
amrit is on a distinguished road
while iterating a case of dynamic meshing, using FLUENT 6.2.16, i got a "negative volume error"... can ne1 plz tell me the various possibilities for the above mentioned error..plzz help..... thank you!!!
amrit is offline   Reply With Quote
Old   February 19, 2010, 02:14
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
Investigate the reason for negative volume.
Typically it is a MDM parameter issue.
It can ba also due to a high time step.
Did you check your mesh motion?
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   February 20, 2010, 01:20
Thumbs up
Amrit
yeah..i checked mesh motion... it worked out well with 0.00005 s as time step bt showed the error when i increased the time step to about 0.007s... may b its due to "time step" in my case... thanks a lot...
Old   February 25, 2010, 13:26
aounallah is on a distinguished road
the minimum negative volume is due to grid generation
any grid had this message when you check it, the calculation don't start
return to gmabit and verify the mesh first
aounallah is offline   Reply With Quote
Old   February 26, 2010, 02:07
-mAx-'s Avatar
Maxime Perelli
No correlation with Gambit
Old   February 26, 2010, 02:08
-mAx-'s Avatar
Maxime Perelli
His initial mesh should be fine, and the error appears as the mesh is moving.
So it is a MDM issue, and it should be solved within Fluent. Gambit has nothing to do with Remeshing stuffs (Moving mesh)
UDF: DEFINE_CG_MOTION for vertical jump motion of an electrode! alban Fluent UDF and Scheme Programming 2 June 8, 2010 19:54
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 22:14
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 21:30
solve negative volume error sravan Main CFD Forum 1 September 26, 2007 22:57
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 16:16
