parallel 6DOF UDF....
Old   February 17, 2010, 23:22
Default parallel 6DOF UDF....
USMAN
usman naseer is on a distinguished road
hi everyone,,
i am simulating store separation in Fluent using 6DOF solver.The mesh size is 2.3 million and it is tetrahedral grid.Now the problem is if i run it on a single node, my system goes out of memory.So i have to use parallel processing.But in parallel processing,after 1st time step, i get the following error.
unable to read cmd header on pmi context:generic socket failure........
and
MPID_SOCK_WAIT:The specified network name is no longer available...
and befor that ,durine the compilation of udf,i get a warning as well i.e;
the specified directory is not shared.This may cause file opening issues across the network.
I am using Windows xp ,Quad node processor with 2 GB of ram.
Can anyone help me in this regard??
Regards
usman naseer is offline   Reply With Quote
Old   February 18, 2010, 15:56
Default parallel UDF
meb
Marco Evangelos Biancolini
meb is on a distinguished road
I think that you can have a quick fix to your problem contacting the ANSYS support... UDF usually are not included in the support but I remember that the 6 dof model comes with standard fluent version.
meb is offline   Reply With Quote
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 23:14
sharing the directory for parallel 6DOF UDF... usman naseer Main CFD Forum 1 September 6, 2010 05:09
sharing the directory for parallel 6DOF udf.... usman naseer Fluent UDF and Scheme Programming 0 February 16, 2010 13:37
sharing the directory for parallel 6DOF udf .... usman naseer FLUENT 0 February 16, 2010 13:29
udf compile in parallel system tahereh FLUENT 1 December 9, 2008 10:48
