February 16, 2010, 21:23 |
Channel flow acceleration
Capslock Roberts
I simulated a 2D planar channel flow with a velocity-inlet on one side, and an outflow BC on the other, with no-slip walls on both sides. The channel is 10m x 1m and the velocity is 0.01 m/s (Re ~ 600 using air), so it should fully develop long before reaching the outflow BC. The problem is that when I simulate it, the flow speeds up rather than slow down. Boundary layers do develop at the walls, and the static pressure does drop, but velocity is accelerating rather than decelerating. The problem does converge rapidly. Would anyone have any idea what the trouble could be?
channel flow |
wallHeatFlux for heated walls in laminar channel flow | svens | OpenFOAM Post-Processing | 0 | June 20, 2009 21:33 |
Channel flow set up | Jung | Main CFD Forum | 2 | November 21, 2007 07:51 |
The initial condition for turbulence channel flow | Ma Jianfeng | Main CFD Forum | 1 | April 20, 2005 04:50 |
Stabilizing turbulence equation in channel flow | Biga | Main CFD Forum | 5 | March 22, 2005 21:06 |
Inviscid Drag at subsonic, subcritical Mach # | Axel Rohde | Main CFD Forum | 1 | November 19, 2001 13:19 |
