How to define a mass source at a velocity inlet ?
Old   February 15, 2010, 11:26
Default How to define a mass source at a velocity inlet ?
sed
cfdiscool is on a distinguished road
Hallo all
I am trying to define a mass source where the high pressure water should be supplied, this is thorough nozzle, I defined the nozzle volume(int) as fluid and now when i turn on the mass source term I see that i have to define the mass source per unit volume
units are kg/m^3-s
what is this unit volume ? i have a numerical value of mass flow rate at the inlet of this nozzle which i have in kg/s... what is the unit volume in this case ...a cell or entire volume of the nozzle...
any suggestions please???
thanks
Life is not always converging ... but u can relax
cfdiscool is offline   Reply With Quote
Old   February 17, 2010, 11:57
Default mass source
CFDtoy
CFDtoy is on a distinguished road
Code is Finite Volume My friend. so, define, mass per volume please. Basically, we do
d(rho)/dt*Vol(cell) + sum (flux) = Source *volume (cell)
Before solving the problem, volume is multiplied to the entire eqn in the Finite Volume method.
You provide per volume and it will compute the source appropriately.
btw, if it asks for per volume, it is the cell volume not the nozzle.
Hope this helps.
/CFDtoy
Originally Posted by cfdiscool View Post
Hallo all
units are kg/m^3-s
thanks
CFDtoy
CFDtoy is offline   Reply With Quote
Old   February 17, 2010, 12:22
sed
After a long and long head scratching i found out the fact behind this unit system....
answer to my question can be as follows:
the mass source per definition in FLUENT is per unit volume...
so mass source has units as kg/s in SI units , since all sources are to be assigned in SI units
The units of "unit volume" is m^3.
This "unit volume" can be a single cell where the source lies or a fluid domain which acts as your source.
simply to input the value of mass source one needs to do following
(mass flow rate)
-------------------------------- units are (kg/s)/m^3
(volume of the source)
volume of the source = (surface are of the source zone)*(height of the source zone)
please correct if am wrong
wishes
Old   September 4, 2011, 12:59
Default answer + another question
KOX
PAWEŁ
KOX is on a distinguished road
Send a message via Skype™ to KOX
Hi there
I think you interprete corectly how the mass source works. I think the same.
However could you tell me please if this mass source works in your model, whatever you were trying to simulate? In my case even if I set some certain value (kg/(m^3*s)) the mass sourc doesnt work. There is nothing released from the source even if I add additional momentum source.
Help please
PN
KOX is offline   Reply With Quote
Old   June 26, 2014, 04:00
Default 2D mass source flow
RAHUL H KUMAR
rahulhkumar02 is on a distinguished road
Hello friends,
I am working on a film cooling simulation in a 2D geometry with Fluent. Ansys Workbench 14.0 is used. For this I am using a mass source for the coolant chamber . But, before going to the exact problem, I need to validate the method of use of source flow in 2D, either in a simple duct or pipe flow cases. Please suggest me with links or articles where a simple 2-D mass source problem is dealt in Fluent. Hope someone help me soon.
Thank you.
rahulhkumar02 is offline   Reply With Quote
mass source, unit, volume, volume integral
Introducing mass source function by SEM method Mehdi BEN HAJ Phoenics 0 December 4, 2007 15:44
Define an equation for the inlet velocity profile Alshroof CFX 3 January 9, 2007 20:34
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
UDF Scalar Code: HT 1 Greg Perkins FLUENT 8 October 20, 2000 13:40
UDFs for Scalar Eqn - Fluid/Solid HT Greg Perkins FLUENT 0 October 14, 2000 00:03
