VOF source terms (Momentum and Mass)---How to define them ?
Old   February 13, 2010, 22:10
Default VOF source terms (Momentum and Mass)---How to define them ?
sed
cfdiscool is on a distinguished road
Hallo all
My model is steady 3D VOF...I have to simulate flow out of a nozzle now
for this fluid region flowing through the nozzle volume region ( water is secondary phase) definition of Mass source is necessary...
as a rule, momentum sources and turbulence term sources (k epsilon)) MUST also be defined after defining the Mass source..
The values of source terms are per unit volume in FLUENT according to definition:
I am NOT using any UDF.... I want to directly give a constant value of mass momentum and turbulence sources:
As I have gone through the FLUENT manual, it says that for a fully developed duct flow
the turbulence length scale can be derived through the formula l = 0.07 L.
Basing on this k epsilon and turbulence Intensity can be derived using respective formulas.......
so I did calculations this way....and obtained values for above flow variables
My question
1.can I now assign these calculated numerical values to source terms in the Boundary conditions of my fluid zone in the nozzle (a 3d Cylinder of small radius < 1 mm)
2. I have to define momentum in x y z direction separately, How can I do this? The units are strange and confusing
suggestions are most welcome ......
thank u
Life is not always converging ... but u can relax
cfdiscool is offline   Reply With Quote
mass, momentum, source, terms, vof
Error message: Insufficient Catalogue Size Paresh Jain CFX 33 August 16, 2024 06:09
Mass source, Momentum source theory. diffo FLUENT 4 August 21, 2009 11:26
Problem with Mass source, Momentum source theory diffo Fluent UDF and Scheme Programming 0 August 20, 2009 07:10
how to define momentum source charonly FLUENT 1 September 8, 2006 04:45
Mass transport, momentum source and turb K.E CFDtoy FLUENT 0 April 24, 2006 01:33
