Ammonia-liquid modelling. Problem with thermal expansion coefficient. |
February 9, 2010, 16:06 |
Evgeny
Good day to all,
I'm beginner in fluent modelling and now encounter with problem: The task is simple- there is a wall modelling (material- ammonia-liquid) with two sides (right- temperature function from x coordinate, y coordinate and time, initial temperature- 293 K and left- temperature constant 360 K) The problem is next: When I set material density I use boussinesq, in this case also should be difined thermal expantion coefficient (which is 0.00245 for liquid ammonia). In this case solution is not converged (laminar or other wiscous model- doesen't matter), however if I reduce this coefficient (0.00245*10^-3= 0.00000245) for the solid values (x*10^-6) all converged perfectly (except common sense) Also I tried to use piecewise-linear function (using formula: p(t)=p0(1-b(t-t0) for density in second point but the result was the same) I will be thankful if someone told me where the problem is. |
boussinesq, fluent, temperature, wall, wallfunction |
Can FLUENT model the expansion of a liquid? | Ahmad Falahatpisheh | FLUENT | 2 | March 11, 2008 04:18 |
thermal conductivity in conduction problem | sangeeta | Main CFD Forum | 5 | August 30, 2007 01:51 |
Single Bubble | Gerrit Senger | CFX | 4 | March 12, 2007 17:29 |
Info: Short Course On Thermal Design of Electronic Equipment | Arnold Free | Main CFD Forum | 0 | August 10, 1999 11:18 |
Problem in Result of the pressure coefficient | Ken Choi | Main CFD Forum | 2 | March 15, 1999 05:15 |
