May 4, 2013, 04:30 |
#121 |
bhushan patil
Rep Power: 14 |
to cfd les
which mehtode u r using for find out moment and plz share u r images of mesh file ...as i share it .....will specify all details then i will able to help u ........... |
May 4, 2013, 04:45 |
#123 |
bhushan patil
Rep Power: 14 |
i am taking moments from report forces --moments -- here u have to specify centre of roatations of moments which u wanted if u r centre is zero zero then give centre of roations =00 ... ya i am taking that momont is torque ....
May 27, 2013, 16:07 |
#124 | |
Rep Power: 13 |
hi dear esp i have the problem as you had. my torque amounts which are take from turbine are too big . what can i do?? how did you figure out your problem? |
May 27, 2013, 16:40 |
#125 | |
Rep Power: 13 |
i had simulated a wind turbine using fluent and now i want to calculate the power out put i,m using this formula: p=torque (NM) *omega(rpm)*2*pi /60 and my rotation axis is y and my center of rotation is (0,0,0).i had set my moment center on (0,0,0) too. the amount of this power output is 10 times bigger than real results. what can i do would you plz help me?? Last edited by niloogh; May 27, 2013 at 17:47. |
May 27, 2013, 17:06 |
#126 |
bhushan patil
Rep Power: 14 |
i thought u r formula for calculating power is worng ..use...............
power= cp /(1/2 * raho*A*Vinfi ^3) |
May 27, 2013, 17:45 |
#127 |
Rep Power: 13 |
May 28, 2013, 02:17 |
#128 |
bhushan patil
Rep Power: 14 |
HERE CP=Coefficeint of power ,
raho= dencity of liquid for water =1000 for air=1.998, Vinfi = inlet velocity kkkkkkask if u need any help |
May 28, 2013, 06:10 |
#129 |
Rep Power: 13 |
May 10, 2014, 18:01 |
#130 |
shafqat
Rep Power: 12 |
hi....can u please tell me why i get negative cm all the time...i have used tri meshing in icm cfd and sliding meshing technique....
May 12, 2014, 01:50 |
#131 |
bhushan patil
Rep Power: 14 |
May 14, 2014, 19:53 |
#132 |
shafqat
Rep Power: 12 |
i am using ke realizable enhancement wall treatment ........for reference values i use swept area in area and length of turbine in length
August 1, 2014, 02:58 |
CFD of propeller
#133 |
M Mohsin Iqbal
Location: National University Sciencies & Technology, Pakistan
Rep Power: 12 |
Hi i am doing CFD of aircraft propeller.
i want to know torque which i got from fluent is ok ???? thrust force which i got from fluent is ok ????? or there is need to calculate thrust by momentum equation for it.. . . . . i.e T = [ MASS FLOW RATE * (Ve - Vi ) ] looking forward. thanks |
March 27, 2016, 20:51 |
LES vs K-w turbulence model simulations on wind turbine rotor
#134 |
Nisar Fatima
Rep Power: 12 |
Hi all,
I am doing unsteady CFD simulations on 3 bladed NREL wind turbine rotor using k-w as well as LES technique with rotational velocity of 14 rpm with wind shear at inlet ( udf).Operating pressure as 1 atm and at outlet radial eq. pressure distribution. But m getting pressure coefficient value for different sections of blade in the range +20 to -70, using both models. I doubt the values coz always I have never seen such high values. Following inputs have been used: regarding mesh : I meshed the blades in ICEM with proper mesh check and 15 prism layers unstructured mesh and sufficiently finer( as per the requirement of LES). Fluent : Velocity inlet with wind shear and TI :0.15, Turbulence viscosity ratio: 10 At first, steady simulation were carried out for 1000 iterations using MRF and kw model. Once flow gets stabilized, changing it to transient and sliding mesh and using steady flow results for initialization . Pressure-vel coupling :SIMPLE (in both models). Reference values from velocity inlet) Area:238 (planform of single blade) Length:1 (later can be changed in matlab as variable chord distribution in the blade) pressure: 0 atm( operating pressure is already 1 atm) I want to ask where have I done mistake because of which m getting such high values for pressure coefficient? Any help would be appreciated. kindly reply |
Help for setting 3D boundary condition in compressing water vapor | sogolf | FLUENT | 0 | September 27, 2009 16:05 |
Boundary condition setting for water hammer proble | yizhou | FLUENT | 1 | October 12, 2007 13:16 |
Need help setting a boundary condition... | HSeldon | FLUENT | 2 | August 28, 2006 15:10 |
Warning 097- | AB | Siemens | 6 | November 15, 2004 05:41 |
setting a body force as a boundary condition | blair | CFX | 1 | April 5, 2003 16:36 |
