Parallel Processing on ANSYS FLUENT 12
Old   February 2, 2010, 17:11
Default Parallel Processing on ANSYS FLUENT 12
srr
srr
srr is on a distinguished road
Hi
I`ve been trying to set a computer cluster for parallel processing on Fluent v.12 and I found some problems.
-When I choose hp as MPI type it ask me a password, I tried with my windows password but it didn't work (It worked just when I chose mpich2 as MPI type).
-On the other hand I always have a problem with the fluent root path, because when i want to turn it in a network path it says that the folder is not shared but it is. Anyway if I ignore that, it says that there is no problem if the software has the same path on both computers (which is the case), so I continue and when Fluent is on it says again that the folder is not shared.
I don't know what to do, if someone can help me I'll be grateful.
Thanks.
srr is offline   Reply With Quote
Old   February 2, 2010, 22:23
wukong is on a distinguished road
Hi
Can you rsh other computer in your cluster without a password? If not, you probably need to make it work first.
Regards
wukong is offline   Reply With Quote
Old   April 16, 2011, 15:16
Default Basics of Parallel Processing
Anand S. Biradar
Anand S. Biradar is on a distinguished road
Hey I need help in Parallel Processing, I want to make Cluster of two Dell Laptops plz guide me from basics as I need it to solve a #D turbine problem
Anand S. Biradar is offline   Reply With Quote
fluent, parallel processing
problem of running parallel Fluent on linux cluster ivanbuz FLUENT 15 September 23, 2017 20:12
Fluent parallel license problem brothershuai Main CFD Forum 0 July 1, 2009 16:41
Fluent parallel poovanna FLUENT 0 March 24, 2007 00:22
FLUENT to ANSYS Temperature Mapping Procedure schreiberc1 FLUENT 0 June 29, 2006 14:50
FLUENT parallel run Sampath FLUENT 6 November 24, 2004 10:52
