heat transfer in solar air heater
Old   January 27, 2010, 03:02
Default heat transfer in solar air heater
A.Siva Arunachalam
arunachalam.siva is on a distinguished road
Hi friends
I am a new user of cfd forum.
I want to analysis solar air heater in fluent.
I designed solar air heater with fins in gambit.
I apply heat flux in underside of the absorber plate.
I split the solid from fluid volume in gambit.
I analysed this problem in fluent and i got a result.
But when i increase a inlet velocity the base temperature reduced at the same time outlet temerature also reduced.
Our aim is increase outlet temperature with increse in inlet velocity.
Anybody help me for tactle this problem.
arunachalam.siva is offline   Reply With Quote
Old   March 1, 2010, 14:20
Default Energy balance previous to CFD
tony00 is on a distinguished road
I would do an energy balance of your system: Energy in = Energy out.
Energy in:
1) Your heat flux times area
2) total enthalpy of the incoming air
Energy out:
1) total enthalpy of the heated air
You will see that your results are consistent: for a higher flow rate (you specified higher velocity) you get lower temperature out.
To optimise your solar collector I would recommend you use natural convection model ( you can either use boussinesq or define a temperature dependent air density, first option is best).
Regards
tony00 is offline   Reply With Quote
Old   March 3, 2010, 03:07
Default Thank u
A.Siva Arunachalam
Thank u for ur reply
I have another doubt
I apply heat flux in base side of the plate
Our sir told apply heat flux in base the temperature of the base only reduce but the temperature of the air does not increase.
Is it right please explain me?
Old   April 17, 2013, 15:43
ram_call's Avatar
ram
ram_call is on a distinguished road
of course as u increase inlet velo, temp will fall in outlet
ram_call is offline   Reply With Quote
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Convective / Conductive Heat Transfer in Hypersonic flows enigma Main CFD Forum 2 November 1, 2009 23:53
air bubble is disappear increasing time using vof xujjun CFX 9 June 9, 2009 08:59
heat transfer: air in a room and water in a coil Alberto CFX 2 May 9, 2006 10:56
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
