Wall induced convection and fluid velocity, how? |
January 25, 2010, 14:06 |
Rep Power: 17 |
I would like to ask you again. I want to generate fluid velocity just by temperature difference of the fluid and a warmer wall on the ground. I have the Fluent 4.5 Update Manual and tried to replicate the tutorial "boiling water in a container" but "unfortunally" I have fluent 6.3.26 on this pool pc and somehow the optioned changed significantly, so that I don't know how to do this by myself. My aim is to combine my current work with a velocity input v>0 and with a wall inside inducing additional velocity just by its heat. I tried to do this by trial-and-error, but this was not successfull and causing errors. I tried "define-modles-energy" and set another temperature under "Boundy Conditions - wall - termal" but this wasn't helpfull. Could you please give me a hint, or something usefull? Thank you in advance, Andreas |
convection, induced, velocity |
Heat transfer BC at wall- why need wall thickness? | Julie | FLUENT | 7 | February 3, 2012 22:41 |
Natural convection - Inlet boundary condition | max91 | CFX | 1 | July 29, 2008 21:28 |
Natural convection over a vertical wall | mimi | FLUENT | 5 | February 3, 2008 21:05 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 20:13 |
heat convection in a forced fluid | Daniele | COMSOL | 0 | December 20, 2005 09:09 |
