parallel processing Fluent 6.3.26
Old   January 21, 2010, 03:07
Default parallel processing Fluent 6.3.26
ck3
Khaled
ck3 is on a distinguished road
I have a PC (AMD 4 processor 64 bit) and my operating system was Windows 64 Vista ultimate. I always launched parallel processing with "fluent -t4" instrucion and it was working without problem.
Now and after formatting my PC, and when I want to launch it I receive this error message " Windows do not find 'fluent' ".
where is the problem.
note: I installed same Windows.
ck3 is offline   Reply With Quote
Old   January 21, 2010, 13:37
mariachi is on a distinguished road
check the Environment variables of ur computer
in windows seven 64 bit, (seven and vista will have the same procedure i guess):
goto my computer properties,
goto advanced system settings,
then click on environment variables,
in the system variables list, select path and click edit,
now to this path variable, add these two paths
c:\fluent.inc\;c:\fluent.inc\ntbin\win64\
note that ur fluent.inc folder should be placed in C drive directly not in some other folder like program files or something else
hope it solves ur problem...
for 3d case u have to use "fluent 3d -t04" command, i have never used simply "fluent -t04" ...... :s
mariachi is offline   Reply With Quote
Old   January 21, 2010, 17:26
ck3
Khaled
Thank you very much for your answer, I followed the stages of your method and it works very well.
I have another question:
Is't the same procedure for Windows xp and Win 32?
Once again…. Thank you!
Old   January 21, 2010, 18:49
wukong is on a distinguished road
Yeah, it is same. Btw, I used XP
wukong is offline   Reply With Quote
Old   April 3, 2013, 01:40
Default hello
yachharesh
yachharesh is on a distinguished road
Hello friends ive installed fluent 6.3.26 in my laptop having windows 8 . also I am doing project based on cfd analysis of direct injection ic engine. Can this software be used to analyze the combustion. I am new to software how to start with it.what are the commands to be used to start the software
yachharesh is offline   Reply With Quote
Old   October 29, 2013, 03:53
FHydro
flow_CH is on a distinguished road
Hello
I have a problem. I am using fluent 6.3.26 in win7 64 bit but in launcher panel for parallel processing i do not have any option. please see this pic
http://axgig.com/images/67172244551068478741.jpg
I did second post of this topic but after typing "fluent -t04" fluent writes "invalid command"
Thanks
flow_CH is offline   Reply With Quote
Old   October 30, 2013, 01:44
Originally Posted by flow_CH View Post
Hello
Thanks
Confirm did you check this step: note that ur fluent.inc folder should be placed in C drive directly not in some other folder like program files or something else
Parallel fluent 4 nodes machine (Quad 6600 SUSE) Rafa FLUENT 4 June 7, 2011 07:33
HP MPI warning...Distributed parallel processing Peter CFX 10 May 14, 2011 07:17
Fluent parallel poovanna FLUENT 0 March 24, 2007 00:22
About parallel processing in Linux tuks CFX 10 August 8, 2005 09:22
Parallel Fluent on Linux clusters Chengwang Lei FLUENT 3 November 24, 2004 03:05
