HELP!a problem when starting the unsteady iteration in Fluent
Old   January 19, 2010, 09:56
Default HELP!a problem when starting the unsteady iteration in Fluent
xuusst
usst139 is on a distinguished road
I have a problem when starting the unsteady iteration in Fluent,and it said——"warning:non-positive volumes exist.
Error:divergence detected in AMG solver ressure correction
Error object)
I guess something wrong with my original grid in Gambit?
hELP ME!THANK YOU!
usst139 is offline   Reply With Quote
Old   January 20, 2010, 13:41
Raditya Wiranegara
radix is on a distinguished road
You might to reconsider your meshing result from GAMBIT. Check your mesh result. Have a look on your right corner of your GAMBIT window to this. The 'non-positive volume' exist due to the highly-generated skewness.
As for the divergence problem,you can prevent this by setting your 'under-relaxation factor'. Make it smaller.
Hope this short reply would solve your problems.
Regards,
Raditya
radix is offline   Reply With Quote
Old   January 21, 2010, 02:37
Smile
xuusst
Thank you for your kind advice,Raditya
Yes,the blade in my model has a very high skewness,so I 'm trying to use the Boundary Layer or Sizefunction to make a better mesh
Problem with Fluent Parallel DarrenC ANSYS 0 October 27, 2009 06:38
Fluent dpm (unsteady) problem! Urgent! Aris Nikolopoulos FLUENT 0 January 17, 2008 08:54
Problem in Tutorial problem of fluent Phanindra FLUENT 5 April 17, 2007 10:57
Problem in Reporting Unsteady Particle Fates Nelson FLUENT 0 August 23, 2006 21:24
starting fluent under freeBSD4.9 Herakles FLUENT 0 June 2, 2004 10:05
