Problems with the unsteady flamelet Model
Old   January 13, 2010, 06:42
Default Problems with the unsteady flamelet Model
Christoph_84 is on a distinguished road
Hello everybody,
I am try to simulate a natural gas flame using the unsteady flamelet model. On the steady flamelet model it works fine. The first model I made works with the unsteady flamelet model. Then I draw a new grid an set up a case based on the first one (same flamelet, PDF, boundary conditions, turbulence model…). There I can’t choose the unsteady flamelet model.
The flow field is conjugated, the solver stands on steady.
Any Ideas?
Christoph_84 is offline   Reply With Quote
Old   January 13, 2010, 09:20
Default Probleam solved!
I had to import the chemkin file again!
Old   April 24, 2015, 17:20
sanjeet Limbu
sanjeetlimbu is on a distinguished road
Hi
After getting the steady flamelet I am not able to initialize unstaedy flamelet for partially...premixed.. it shows the mixture fraction error. I am trying to ignite the nheptane/N2/Ar/O2: 0.562/58/30/10.3 , by mole fraction
I am getting only the steady flamelet
Please help me how to reduce or set the mixture so to avoid this error.
I am trying by putting the scaler to all possible values between 1 to 0 the error is not disappearing
I am in bit great need ... Pl help
sanjeetlimbu is offline   Reply With Quote
non-linear k-epsilon model implementation problems Saidi Main CFD Forum 2 March 4, 2010 14:23
unsteady flamelet models dean Main CFD Forum 2 October 5, 2005 20:22
Unsteady Flamelet modelling Les Denpre Main CFD Forum 0 August 8, 2005 10:46
Model problems FP Mie FLUENT 0 February 25, 2001 10:17
k-omega model and unsteady transition Jens Thurso Main CFD Forum 1 May 4, 1999 10:50
