January 1, 2010, 20:20 |
convert to real in gambit
erh
Rep Power: 16 |
Hi all,
i am using gambit 2.2.30. i working on a project. i have drawn pipe in Cativa V19. i am importing gambit but could not convert to real. could anyone give me information how to convert to real? sincerely yours |
January 1, 2010, 21:53 |
teguh hady
Rep Power: 17 |
To convert it i think you can choose option below Boolean logic. there is button to convert virtual to real. Hope it helps!! teguhtf
Now Or Never!!! |
January 2, 2010, 08:59 |
erh
Rep Power: 16 |
January 2, 2010, 10:06 |
teguh hady
Rep Power: 17 |
In some case you can convert it at once if there is simple geometry (some faces). but if there is complex geometry, convention doesnt work. Sometime i cut in pieces to repair virtual things. Anyway, there is no differences between real and virtual on your final mesh. but Boolean logic work in real things only.
hope it helps teguhtf
Now Or Never!!! |
January 3, 2010, 09:33 |
#5 | |
erh
Rep Power: 16 |
January 3, 2010, 16:35 |
teguh hady
Rep Power: 17 |
You're welcome. For further information about gambit tips & trick in http://www.anova.com.tr/dosyalar/destek/gambittips.pdf
or you can read gambit manuals (there are much site upload it on the net) there are much information about gambit usage!!! Hope it helps teguhtf
Now Or Never!!! Last edited by teguhtf; January 3, 2010 at 16:39. Reason: completing |
January 5, 2010, 01:29 |
Maxime Perelli
Rep Power: 41 |
if your import gives you an virtual volume, you won't be able to convert it into real.
Try to import it as STEP file, the result should be a real volume. Handling with real volumes, is just a MUST if you need to work with boolean operation. (extracting fluid volume form solid is the only operation which needs boolean operation (from my side). All the others can be handled with virtual tools) But working with real volumes is much easier than working with virtual ones (but not impossible)
In memory of my friend Hervé: CFD engineer & freerider |
January 11, 2010, 03:13 |
YH Tan
Rep Power: 17 |
I normally use parasolid files (.x_t) to import solid into gambit.
All the complex geometry i imported keep remain Real so far. Take a try.
Herntan, Add Reputation if I am right |
how to hook this udf | shanu | FLUENT | 1 | August 26, 2011 10:48 |
gambit and real volume | simona | FLUENT | 5 | May 2, 2011 02:22 |
Parallelizing a UDF | tstorm | Fluent UDF and Scheme Programming | 3 | August 20, 2009 12:31 |
udf error | Rashmi | FLUENT | 0 | December 27, 2005 05:35 |
Convert Real edges to Virtual in Gambit | Freeman | FLUENT | 6 | October 24, 2005 15:14 |
