making sprial coil in Gambit
Old   December 28, 2009, 18:17
Default making sprial coil in Gambit
Wael Aly
aly_wael is on a distinguished road
I have a problem in making a spiral coil in Gambit. After putting many points and made spline and swipping the circular meshed face on the meshed spline I got the volume but when exporting mesh gives error of higher order elements. I can not make it using ACAD as I can not save STEP OR IGSC files. Please advise. Wael
aly_wael is offline   Reply With Quote
Old   January 1, 2010, 23:06
teguhtf's Avatar
teguh hady
teguhtf is on a distinguished road
Try to split in some volume then mesh each volume. maybe it can reduce your complex geometry. you can use FLUENT 12 cause it works in AUTOCAD 2009. but maybe there is something wrong about its connectivity.
teguhtf
Now Or Never!!!
teguhtf is offline   Reply With Quote
Old   January 2, 2010, 10:41
Wael Aly
Thanks teguhtf, I will try.
Wael
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 02:24
Problem making a periodic boundary in helical coil Mikael FLUENT 0 January 24, 2008 11:22
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
Making modifications in GAMBIT Vidya Raja FLUENT 15 July 12, 2006 15:58
