2D flow around a rotating cylinder
Old   December 22, 2009, 16:26
Default 2D flow around a rotating cylinder
king lui is on a distinguished road
Hey everybody,
I have a problem by working with Fluent.
The tolerance of my y+ value is between 50 and 500
but the range of the rotational speed of my cylinder is very large
Therefore some problems occur
for example if the cylinder is rotating by 100rpm the y+ value is in tolerance
but if the cylinder is rotating with 1000rpm with the same settings the y+ is not anymore in the tolerance and therefore i use the function - adapt -yplus/ystar - adapt
this pushes my y+ value back into its tolerance.
i think this affects my accuracy when i do this adapt funtion
because if i do this for example until 8000rpm and always push my y+ into its tolerance and go back at the end from 8000rpm to a smaller value for example 500rpm the adapt function is necessary again and after that my result of the lift has a big deviation from my first result in the case of 500rpm.
maybe someone can help me with that problem, thanks a lot for that
king lui is offline   Reply With Quote
Old   December 22, 2009, 21:59
Anshul Mittal
anshulmittal1912 is on a distinguished road
How are you treating the walls? Are you using the standard wall functions?
anshulmittal1912 is offline   Reply With Quote
Old   December 23, 2009, 11:59
yes, i am using the viscous model k-epsilon with its standard settings, so with standard wall functions.
Old   December 23, 2009, 20:53
Anshul Mittal
Take a look at the Fluent manual.
It says that the wall functions are not good in regions where there is boundary layer separation. This might be the problem. I am not sure about the adapt function.
Anshul
Old   December 24, 2009, 06:46
Anshul
okay, thats a useful information, i will try some things in fluent,
thanks for your help so far
Old   December 24, 2009, 07:56
just one question, where i can find the fluent manual for the version 6.3.26
cause the links in the forum donīt work
Rotating cylinder raul FLUENT 3 February 1, 2015 06:48
Moving a Cylinder in cross flow after solving Dynamics equations of motion maruthamuthu_venkatraman OpenFOAM 1 November 19, 2009 14:55
Flow over a cylinder Anna Main CFD Forum 9 March 24, 2006 15:32
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 13:19
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 22:31
